"Frequency change to"
sebasira
Senior Contributor I
Hello!
I'm getting the message "Frequency change to ~xxxxxx khZ" I now that this could mean:
- Small Stack
- Invalid address writting
- Overwritting return value of function call
Is there any "easy" way to catch this?
Thank you all!
Best Regards!
Sebastian M. Irazabal
sebasira
Hi David!
Thanks for your concern! Fortunately we've solve the problem. I don't remember exactly, but it was related to the USB BDM.
Best Regards!
SebaS
DavidS
Hi Sebasira,
Hopefully you have found the problem.
If not please give additional information to help us help you.  What device, hardware, show software example, etc.
I recommend searching the code base for that message and try to figure out why it is called.
David
sebasira
Hi David!
Best Regards!
SebaS
