no responce from BDI
3,101 次查看
rao
While I am tryibg to dump the code , I am  Getting the following error.
Abatronprotocolplugin:BDI:no responce from BDI
 Can any one help me regarding this issue.
Thanks in advance.
1,409 次查看
Chandrashekar
Hello Rao,
In the Remote debugger option under Target settings of the CodeWarrior IDE
set the connection settings tab to PEMICRO_PARELLEL(or select the mode of debugging).
Hope this will solve your problem
