freescale I2C information
2,087 次查看
nms
hi,
I am using Freescale  MCF52259 for I2C  basedapplication.
In this application, I  am  using LH7A400 as a I2cmaster( It does not have On Chip I2C So I am using soft I2C).And MCF52259 acts as a I2C slave. Is this type ofcombination possible?
I am sending only Slave Address but not able to read fromSlave.
Is there  any I2C Slave code available ?
Please guide me, I am new to Freescale .
标签 (1)
1 回复
1,344 次查看
bluehacker
mcf52259's i2c module can addressed as a slave device. you should set the I2ADRn register , this register holds your slave address when you use mcf52259 as a slave
