codewarrior import mcp text-based project file
dirkricker
Fresh Out Contributor
I am trying to import an old MCP file into CodeWarrior 10.6.4 for a ColdFire V1 processor.  I go to Import->CodeWarriorClassic Project and select the MCP file.  The dialog states that "Text-based project file not supported. Press F1 for information on converting text-based projects to binary."  However, the F1 results in "The context help for this user inteface element could not be found."  Is there a way to take this text-based MCP file and turn it into the format it is looking for?
Thanks!
#ClassicCodeWarrior‌ #ImportClassic‌ #codewarrior coldfire‌
miduo
I am not sure what CW classic version you would like to import to CW 10.6. Actually CW10.x does not support text based project. To import your project to CW10.x you need to unceck text based project option within the classic CW and then import it to CW 10.x.
