Setting VBR on 5282
Setting VBR on 5282
1,929 次查看
SVC1
I would like to keep the interrupt table into internal flash.
I would like my application to be at address 0x8000, how do I set up the VBR to this address (since the lower 20 bits are not implemented)?
Simon
1,291 次查看
UK_CF_FAE
Hi SVC1,
The vector table must be located on a 1MByte boundary, and so you will not be able to place it at 0x8000. I think that you will need the vector table at 0x0000_0000.
Mark.
