S912XEP100W1MAL epoxy
3,474 次查看
josie
hi ,
may i know if it is good to use with more than 15% epoxy void, see attached photo?
2 回复数
3,458 次查看
josie
Hi Tom
it is found during visual inspection by X ray.
found lack of epoxy. it is good to use?
3,469 次查看
TomE
Specialist II
This is the Coldfire Forum, for MCF5xxx chips. You want the S912 one, which is here:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/bd-p/16-bit
What happened to that chip? Has it "popcorned" by being reflowed when wet?
Tom
