Register usage and stack frame
DaveRahardja
Where can I find documentation on the register usage strategy for CodeWarrior C++ on ColdFire 52xx? In particular, I want to know how registers are used to pass parameters during function calls.
In addition, where can I find information on the stack frame created during function calls?
CrasyCat
Specialist III
Hello
You find some information around calling convention and stack frame in
{Install}\Help\PDF\ColdFire_Build_Tools_Reference.pdf in chapter "ColdFire Code Generation",
section "Calling Conventions".
CrasyCat
