Node Lock License
Node Lock License
rppolicy
This concerns a legacy purchased licensed product that needs to be run (CW for Microcontrollers version 10.2 Basic -NL).
I have an old node locked license that includes a valid dongle.  I run LMTOOLS and the FLEXID matches my dongle.
According to the getting started guide the Codewarrior Version 10.2 is ready to run.  However, I'm receiving a linker error that the code size limit has been reached.  The code size should be covered by even the BASIC version so I'm in doubt the license is correct.
Is there any way to find out if the license is running or not?  I'm not even sure how to tell CW where the license is.
