MCF5223x real Ethernet performances
1,666 次查看
DownyTif
I would like to know the real performances of this chip over a 100Mbps network. The main application that would run on the MCU would be doing those things:
- Listen for request coming from Ethernet;
- Get 32bits data from GPIO (actually, from an external FPGA);
- Package that data;
- Send that data, package after package, over the Ethernet as fast as possible;
Also, is there any royalties or fees related to the TCP/IP stack?
Thanks a lot
985 次查看
mjbcswitzerland
Specialist V
I have a few measurements here: http://www.utasker.com/docs/uTasker/uTaskerBenchmarks.PDF
The figures depend on protocol and settings and maybe other factors but this may give a starting point...
Mark
www.uTasker.com
