M2233DEMO
M2233DEMO
bagula
I have Vista OS and I am facing problem with installing M2233DEMO as there is no hyper terminal in Vista OS. need help.Thanks
Daniel2312
Another programm that run under vista is HTerm.
HTerm
butok
You may try any other Terminal program.
For example, the opensource&free “Tera Term Pro”.
The latest version you can find here: http://ttssh2.sourceforge.jp
Andrey Butok
bagula
thanks. i shall try.
bagula
RichTestardi
Senior Contributor II
I also use putty: http://www.putty.org/
Putty now supports serial ports as well as sockets.
You can also actually copy HyperTerminal from an XP box to Vista, and it will work as well.
-- Rich
