Linux 2.6.25 on MCF54451
jehoffma
I'm ran into problems getting a Kernel 2.6.25 to run on a custom m5445x board. Sometime when rootfs is mounted the kernel hangs, sometimes means it can either run for days or I don't even get a login. I've got no idea what can be the reason. Any ideas?
Thank.
kmahan
It is hard to provide suggestions since your email doesn't provide any details.
When the kernel hangs WHERE does it hang?
Is the hardware stable?   Did you run the previous kernel on it?
