Initialize Flexcan in MCF5282
keikote
hello,
I'm trying to initialize the Flexcan port and sending a message.
I downloaded a demo "MCF5282SC" from "http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MCF5282&nodeId=0162468rH3YTLC00M95448" to try it but i don't know how can i test the flexcan port.
I try to use an osciloscope to see any signal but i don't get anything.
Can help anybody with the code and the hardware that is necessary to test the Flexcan port?
My board is a custom 5282 based in a 5282EVB.
Thanks in advance.
PaoloRenzo
Contributor V
Did you try to use a code-init-tool like CFinit?
https://www.freescale.com/webapp/Download?colCode=COLDFIRE_INIT&prodCode=MCF5282&nodeId=0162468rH3YT...
I guess it will be a good software start point
About hardware, try to use the same transceiver as we did in our EVB or LITE boards.
Good luck.
Alban fixed link
Message Edited by Alban on 2007-02-12 12:18 PM
