How to disable BDM clock output
1,749 次查看
Stefou
Hello everybody,
I am looking to:
How can I disable the PSTCLK output from a CF5373L. I have many problems on radiated field emission with this approximately 117MHz clock.
We use this clock to synchronize the ColdFire with the WindRiver pod to debug this.
THANK YOU
1,060 次查看
PaoloRenzo
Contributor V
Try to change to JTAG mode using JTAG_EN. That should disable the clockout pin. If this is not enough try to use LIMP mode to reduce emissions.
