Hanging problem
Hanging problem
CHRamesh
What will happen, if we write to a location which is not existing,means if we have 100 bytes of memory, and if I write to 101 or next locations. What will be motorola coldfire controller/Processor behaviour ?
tkvenki
Hi Ramesh,
I think it depends on your .mem file.
If the location is mentioned as Read...and if you write on this location,
Then it would go to hang status.
If you have mentioned the Memory location as ReadWrite, then there will be no error.
But there will be a obvious data loss.
tkv
