Get to Assembler from C
Dwight
I need to drop into the assembler (either in-line or a call), and have access to variables in the C portion of the program.
Also, what registers do I need to be careful about altering/restoring?
Thx,
D
J2MEJediMaster
Specialist I
If you're using CodeWarrior, check the ColdFire Build Tools Reference document (ColdFire_Build_Tools_Reference.pdf) that came with the CodeWarrior installation. You can find it in the CodeWarrior directory, within the \Help subdirectory. In particular, study the section "Inline Assembly". HTH.
---Tom
