Enabled DHCP client by pressing SW2 on DEMO board, got IP was assigned
已解决
跳至解决方案
2,156 次查看
TVNAIDU
I was using LITE stack to force DHCP client to get IP addr from server by pressing SW2 on DEMO board, DHCP client gets IP addr, but this addr was already assigned for some other PC, I was wondering whether this is DHCP server issue or LITE stack Client issue. I was using Netgear Router, sofar this router never assigned like that, any idea?.
TV
标签 (1)
1 解答
1,374 次查看
vier_kuifjes
Senior Contributor I
I haven't seen that kind of problem yet...
I currently have 2 Coldfire devices connected to my router (3com), as well as a couple of wired and wireless PCs and a Wii game console. All work fine, all have their own IP address assigned.
Always make sure every device has it's own unique MAC address, but you probably know that.
Try power cycling your router to reset it's client list and see if it makes any difference. Also, after power cycling the router, do the same with the coldfire board.
在原帖中查看解决方案
1 回复
1,375 次查看
vier_kuifjes
