Enable interrupt MCF52
teto84
Good morning, I have a eva-board MCF5272C3 that mount a uP MCF5272. I use this with a Profibus board (VPC3+ made by profichip) that it need to receive the enable of its interrupt. The engineer of profichip says me to tell you to have these answers. In fact I need of:
1. How to define the interrupt routine in C?
es in the example of Amtel's board, using C51 compiler there is
void ISR (void) interrupt 0
2. How to enable the external interrupt in order to activate the data_exchange, request to send etc etc (to VPC3+)?
Please, I need so fast of your answers
thank you
teto84
thank you
mccPaul
If you search my posts you will see a lot that discuss Interrupts. You can also search for ISR, Interrupt, Handler and these will give you quite a lot of results.
If you want to know how to declare an interrupt handler in C, we need to know the compiler. It is different in CodeWarrior and GCC.
Paul.
