EVB5213 for gcc complier
3,449 次查看
pkb
I am planning to use evb5213 evaluation board from freescale for my project. We are planning to use gcc complier for the same. Where I can get the MCF5213-processor related files (register header files, start up file & other API's) for gcc complier. If anyone having idea on the same please help me.
And also I would like to know what is machine dependent commnd for MCF5213 processor in gcc complier.
Thanks in advance.
Pradeep
4 回复数
1,875 次查看
pkb
I am planning to use evb5213 evaluation board from freescale for my project. I am planning to use gcc complier for the same. Where I can get the MCF5213-processor related files (register header files, start up file & other API's) for gcc complier. If anyone having idea on the same please help me.
Thanks in advance.
Pradeep
1,875 次查看
Petter
I'm not familiar with that particular EVB, but did it come with a CodeWarrior CD? If not, try to see if you can find an evaluation version of CodeWarrior. The extract the header files from the installation.
1,875 次查看
pkb
Hi Peter,
Thanks for ur suggestions. I downloaded the example for the MCF5212 files from freescale site. Those are the examplers that given for codewarrior.
We are planning to use our own development platform which uses gcc complire. But the same heades files, startup file & other API's can I use it for GCC complier?
Pradeep
1,875 次查看
Petter
You should be able to compile the files with gcc. However if you're planning on using gas for assembler you have to add % before the register names in the source files.
