DEclaring vectors in coldfire
micky
hello, i use coldfire mcu v6 compiler with a mcf51JM64 microcontroller and i want to declare a vector and it dowsn't work, it compile it but when a run the aplication it sees value 0 in vector.
Please help, thanks.
TomE
Specialist II
Are you using CodeWarrior? If so, ask your question in the CodeWarrior forum.
Otherwise, WHAT compiler are you using? "coldfire mcu v6 compiler" doesn't narrow it down enough to help.
Tom
