Coldfire newbe
Coldfire newbe
1,544 次查看
IBD
I have just purchaced the MCF52259EVB board and are trying to do a simple RTOS program that sends Hello world out the serial port.
I decided to try using the Processor expert to initalize the device.
I have updated to v7.1.2 However have tot been able to find the release nots instructions for ensuring the processor expert will work correctly.
I have added the MCF52259CAG80 processor to the CPU beans and added UART 0 to thebeans. Set the settings
However I get to errors
1. INTERNAL ERROR: at line 2153 Unknown macro "CW_PRJWIX_MCU_NAME: (file: Drivers\MCF\MCF.drv)
2. INTERNAL ERROR at line 121: File not found sources\ctartcf.c (file: drivers\MCF\codewarrierMCF_plugin.prg)
Can anyone please point me in the right direction.
I have little experiance with the coldfire processor and processor expert feature.
But have great experiance with codewarrier and the HCS12 processor.
1,153 次查看
ProcessorExpert
Senior Contributor III
I haven´t been able to reproduce the problem. Could you please post here detailed step by step process to reproduced it?
best regards
Vojtech Filip
Processor Expert Support Team
