Coldfire MCF52259 Evaluation board problem with the SPI Clock
1,686 次查看
DonnaG
Has anyone had an issue with getting the SPI clock to register on J1 pin 21 on the evaluation board?  Currently I am having an issue with getting a clock signal out.  My register settings are follows:
QMR - 0xA0C8
QDLRY - 0x0101
PORTQS - 0x7F
DDRQS - 9x99
SETQS - 0x6F
PWSPAR - 0x1555
Has anyone used the QSPI_SCK pin on the J1 connector?
标签 (1)
1 回复
1,130 次查看
FWFan
Hi Donna,
Give these codes a try.  Let me know if
some codes are missing.
Good Luck.
