ColdFire Lite is missing dhcpport.h for DHCP Server
daverj
We tried to enable the DHCP server in ColdFire Lite 3.0 and get an error that "dhcpport.h" is missing.
 It is referenced in allports.c when the DHCP Server is enabled, but is not anywhere to be found in the CF Lite 3.0 files I downloaded in November. I just downloaded 3.2 and the same reference is in allpots.c, and dhcpport.h is still missing.
Without it there are several missing functions for getting the DHCP Server functioning.
Does anybody know where this file is, or what is needed to compile CF Lite with DHCP server enabled? (server, not client)
DrSeuss
While there should be a dhcpport.h stub in the project the DHCP server function is not supported in the Coldfire_Lite. You can however purchase this from InterNiche.
