Best software for USBDM to debug MCF51JE microcontroller w/o source code?
2,897 次查看
briandavidson1
ERROR
3 回复数
2,850 次查看
briandavidson1
ERROR
2,847 次查看
Itzzamna_Supp
Thats correct, as mentioned, the flash programmer and debug tools from CodeWarrior can facilitate that.
2,854 次查看
Itzzamna_Supp
Considering what you are saying about the setup, the USBDM and that you need it just to flash the file on the board, the best/recommended software is CodeWarrior 11, by using the flash programmer tool. There you will be able to open your project and then use the flash programmer tool and you will be able to do all the setup.
