About  MCF54418   USB OTG&HOST problem?
1,221 次查看
mengshen
Hi,I found MCF54418 TOWER board not use USBO_DP and  USBO_DM? Why? is the USBO and USBH can not work in the same time? Thanks.
1,068 次查看
t_k
Did you ever find your answer?
I'm just starting to try to use the mcf54418 and was looking for some examples on using the USBO_DP and USBO_DM.
thanks,
Travis
