AN3690 CAN-to-USB Bridge
已解决
跳至解决方案
3,655 次查看
sebasira
Senior Contributor I
Hello!
I'm working on a CAN-USB interface with the JM128. I've found the AppNote 3690 wich discuses about the CAN-to-USB Bridge. In that article, they refer to a code, but I wasn't able to find it. Could anyone provide me that (or any other) example code?
I've also found another thread from "lolachampacar" (Subject: USB to CAN AN3690 Software) who also requested that code.
Thanks in advance!!!
SebaS
标签 (1)
1 解答
2,250 次查看
J2MEJediMaster
Specialist I
Here is the link to the license page to download the software for App Note AN3690:
AN3690SW page
---Tom
在原帖中查看解决方案
3 回复数
2,251 次查看
J2MEJediMaster
Specialist I
AN3690SW page
---Tom
2,250 次查看
sebasira
Thank you soo much Tom!
And thanks for your quick reply!!
SebaS
2,250 次查看
d1
I'm also using the MCF51JM128 USB-CAN solution described in the AN3690. How can I write customized application to talk to the WinUSB FSL driver? Is there any documentation and/or source code of the WinUSB FSL driver and GUI app?
D1
