64 bit signed integer math routines for M68332
idlebrain
I need 64 bit signed integer math routines for M68332, manily I am looking for mod operator in assebly. I tried with ashware gcc to generate the assebly listing, But this generated a library function "moddi3". I could not get source code for 683XX port for this function.
If any one is having idea / sample code / algorithm please help me.
Thanks a million.
idlebrain
ChrisJohns
The code for that function comes from this file in GCC:
http://gcc.gnu.org/viewcvs/trunk/gcc/libgcc2.c?revision=136534&view=markup
It is a little complex so I hope it helps.
Chris
