52235EVB dBUG monitor
3,522 次查看
Petter
This probably a silly FAQ, but I can't find the answer... When I got my 52235EVB it had dBUG installed in the flash so it was started at power-up. However, I've been running some other test programs (uploaded using the USB-BDM) and hence erased the dBUG. But where can I find the dBUG monitor and how do I upload it?
4 回复数
1,234 次查看
wmunlai
Use CFflasher
I used it some time ago. I vaguely remember that u can program Dbug with it.
1,235 次查看
Petter
Thanks, now my next problem is to find the dBUG monitor.
1,235 次查看
mccPaul
Are you sure you had dbug flashed into it? Our 52235 demo board came with the InterNiche stack on it (although we did pick it up at a FreeScale seminar so it could have already been pre-flashed). I can't find a reference to a 52235 build of dbug on any of our CDs so maybe it still needs porting. That should be easy :smileyhappy:
cf_flasher will certainly flash it for you, and it also lets you copy the flash image to disc - but that's only useful if you know that before you've overwritten the flash - sorry!
1,235 次查看
Petter
Thank you for your reply mccp.
My board came with dBUG (it's a EVB, not a DEMO). However, it's still there :smileyhappy:. My serial cable must have been disconnected or something. But I would still like to know where I can get a copy of the dBUG monitor, either source or srec format.
