how to  check the M3 memory after bootloader failed about msc8156
ソリューションへジャンプ
2,385件の閲覧回数
yangjie
          In  mas8156 reference datasheet, it has list the bootloader error code.The bootloader error code will be written in a constant address in M3 in order to indication which error has happend for user if bootloader failed .but i don't konw how to read the content in M3.
Expect your help.
       thanks.
        jie.
タグ(1)
2,002件の閲覧回数
yangjie
         We  can use "Attach"  function.How to use the "attach", the answer is in the codewarrior using sheet.
2,003件の閲覧回数
yangjie
