MSC8156 boot program source code
s_kalop
Hello.
Where can i find C-source code for  MSC8156 boot program (0xFEF00000-0xFEF17FFF)?
Thank you.
Pavel.
lunminliang
Usually this code is not exposing, only for internal usage. Why do you need this code for?
trytohelp
Hi Pavel,
Very sorry for the delay.
Can I suggest you to contact the support team via CRM system ?
Please can you sent an email to [email protected] or used the web system ?
For Technical Support Issues please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - If you are already registered with Freescale (using the Forum, subscribed to newsletter, ...) use your Freescale login and password. Otherwise, Click on "Register Now" to get registered.
  - You can submit your request through the web from there.
Pascal
