Demo project for CPRI Ethernet
已解决
跳至解决方案
2,569 次查看
deep_joshi
I am using CW10.2.5 with MSC8157 ADS board and I am trying to run a demo project under the directory starcore_support\SmartDsp\demos\starcore\msc815x\cpri_ethernet. So I am trying to run CPRI_ethernet project
Now I am facing a problem that the demo project is not able to do the Link rate Auto negotiation step and getting strucked in the cpriLinkAutoNegotiate step.
In this function its trying to get CPRI link synchronized first with link rate 6144 and then goes does to 1288 but in all these rates it is still not able to sync up.
I have read the readme.txt and changed the switch 6 setting to 00010101
Br
Deepak joshi
标签 (1)
标记 (1)
1 解答
2,001 次查看
J2MEJediMaster
Specialist I
You have some scary equipment there. :smileyhappy:
Best course of action for you is to submit an on-line service request for this problem. Click here to go to the on-line service request page.
---Tom
在原帖中查看解决方案
1 回复
2,002 次查看
J2MEJediMaster
Specialist I
---Tom
