C programming
C programming
NagamalleswaraRao
Why default values for auto and register are garbage value and why it is zero for static and extern in C programming?
xiangjun_rong
Can you tell us the part number and the tools you are using? If you use DSC and CodeWarrior for MCU ver11.x, if you do not initialize a variable, the variable maybe any value. Therefore, you have to initialize the variable.
Hope it can help you
Xiangjun Rong
