spanion flash progammer
paulemery
How do you program a spanion S70GL02GS11FH1010 2 Gb, 256M x 16 flash using Codewarrior PA Flash Programmer Task?  All of the flash device selections are small.
yipingwang
Hello Paul Emery,
S70GL02GS is not listed in the flash programmer device list in the latest CodeWarrior 10.5.1.
You could refer to the application note in C:\Freescale\CW_PA_v10.5.1\PA\PA_Tools\FlashToolKit\Documentation\AppNote-FlashProgrammer-PowerArchitecture.pdf to add new flash programming algorithm and device in CodeWarrior.
You could refer to the sample flash programming algorithm projects in C:\Freescale\CW_PA_v10.5.1\PA\PA_Tools\FlashToolKit.
Yiping
