freescale eGUI missing files
shany
Fresh Out Contributor
I'm using freescale eGUI with MCF51AC256.
I have the AN4263_SW.zip folder.
Where can I recieve the following files: d4d_bmp.c+h, d4d_scheme.c+h, d4d_gauge.c+h, d4d_graph.c+h, d4d_icon.c+h, d4d_picture.c+h, d4d_scroll_bar.c+h, d4d_console.c+h.
Shany
J2MEJediMaster
Specialist I
shany
I'm sorry, but I didn't understand your answer - the folder doesn't contain these files.
also - I don't seem to find the touch screen drivers.
Is there another folder (other then AN4263_SW.zip) I'm supposed to use?
Shany
J2MEJediMaster
Specialist I
There has been an issue with the D4D header files not showing up in CodeWarrior IDE, even though they are present. That is why I pointed you to the previous thread.
If they are truely missing, then that's a different problem. Take a look at this https://community.freescale.com/message/88046#88046.
Also, you can use the forum search box (it is located at the upper right of this web page) and trying entering either "D4D" or "eGUI" to look for previous queries on the subject.
---Tom
shany
The files I'm missing are not only heaser files but also code files (for example - d4cd_date.c+h, d4cd_gauge.c+h....)
that simply don't seem to appear in AN4263_SW folder.
I'm also missing the touch screen driver - not for MQX. I'm using MCF51AC256A controller.
Where can I get these files?
Shany
shany
Now I understand that the folder I have is of D4CD and not D4D and the missing files are supposed to be missing
(they were removed from this application).
My question is this - can I work with an independent touch screen driver with D4CD?
Is it possible to get the D4D files?
Shany
J2MEJediMaster
Specialist I
I do not know enough details to help you further on this. Please enter an on-line service request for this problem. Click here to do this.
---Tom
