coldfire: why can't I use the sleep function?
4,046 次查看
Ivychacha
Hi all,
I'd like to use the sleep function in my code and I've found the definition of this function in the CW help:
#include
unsigned int sleep(unsigned int sleep);
But when I tried to use this function in my code i can't compile it, getting link error "undefine funtion: sleep".
Am I doing something wrong? why can't I use this function?
Any ideas? I'm confused :/
Ivy
Message Edited by CrasyCat on 2007-04-13 01:37 PM
标签 (1)
标记 (1)
4 回复数
2,174 次查看
Ivychacha
ok thanks crasycat I see it.
Ivychacha
2,174 次查看
Ivychacha
Hi crasycat,
sorry I forgot that information :smileyvery-happy:
I'm using the ColdWarrior 5.7 on a MCF5235BCC EVB.
Ivy
2,174 次查看
CrasyCat
Specialist III
Hello
  In our embedded products, we usually do not provide source code for time management functions as
 these functions are board and OS specific.
 This leaves customer the choice of implementing their own time management functions.
 If you are using an embedded OS, you may want to remap the sleep function to some OS
 related function.
CrasyCat
2,174 次查看
CrasyCat
Specialist III
Hello
Which CPU are you targeting (HC08, HC12, Coldfire, ...)?
Are you using an OS on your target?
CrasyCat
