aarch64-fsl-linux-gcc toolchain not generating shared libraries
3,461 次查看
sameerarvikar
I am using aarch64-fsl-linux-gcc toolchain with LS2088ARDB
So trying to compile sofia-sip on RDB,i am getting static libraries ,but no shared libraries are generated .similar problem is when i compile opus,speex,zrtp. (I am using ./configure --enable-shared --build=arm).
3,050 次查看
sameerarvikar
its working now
using
--build=aarch64-unknown-linux-gnu
