Hii Yipingwang,
I’m currently working on configuring my target board to fetch the RCW from an SD card. I’ve successfully created a SRAM project in CodeWarrior, and it runs without issues. However, I’m having trouble when attempting to boot from the SD card.
after buffer we placed a pullup resistor on sd_clk with 10k(resistor value)
Observations:
I inserted the SD card into the board and monitored the sd_clk line before and after the buffer, as well as the sd_data0 line.
Here are the details of the buffer I’m using: Part Number: MAX13035EETE+T.
for your reference below i am attaching images
is there any modifications needed please suggest.
