Stateviewer plugin on CodeWarrior 10.2 for ColdFire V1
1,507件の閲覧回数
elecsmith
I am trying to install and run the StateViewer eclipse plug-in with CodeWarrior 10.2 to debug FreeRTOS on a ColdFire MCF51CN128.  The plug-in installs correctly, but does not populate the Task or Queue data when running the debugger.  Instead, I simply see blank windows.  I am debugging with the P&E USB Multilink.  Has anyone succeeded in using this plugin with codewarrior?
タグ(1)
1,237件の閲覧回数
BlackNight
I tried that plugin too, and did not work for me neither.
I have not found any documentation how this plugin is supposed to operate with a debugger, and it looks to me that it does not work with the CodeWarrior debugger.
Too bad.
BK
