QCVS
QCVS
7,867件の閲覧回数
hv
If I download an eval CodeWarrior, does QCVS come with that?  Thanks!
6 返答(返信)
7,303件の閲覧回数
addiyi
You can use also the update site. Go to Help > Install New Software and select FSL PA QCVS - http://freescale.com/lgfiles/updates/Eclipse/PA10_5_1/com.freescale.pa.qcvs_win from drop down menu.
Adrian
7,303件の閲覧回数
hv
Thanks!
7,303件の閲覧回数
yipingwang
Hello H VO,
QCVS tool is not included in CodeWarrior for PA, please download QCVS for PA from CodeWarriorNetworked Applications : QCVS|NXP, then open CodeWarrior IDE and install QCVS 4.5 from Help->Install New Software->Add->Archive, specify the installation file path to follow wizards to install QCVS step by step.
Yiping
6,575件の閲覧回数
Chinzw
@yipingwang   Can you share  the  CodeWarrior IDE and install QCVS 4.5 software  in baidu netdisk again ? Thanks a lot
6,577件の閲覧回数
Chinzw
@yipingwang
Can you share QCVS 4.5 in Baidu netdisk again ? Thanks a lot .
7,303件の閲覧回数
hv
Thank you!
