I'm trying to load the tools to create the RCW for the E5020 QorIQ processor.
I downloaded and installed the base Eclipse software.
eclipse-cpp-juno-SR2-win32-x86_64.zip
The installation guide for the QCVS tool says to point to the zip file:
QCVS.4.2.0_PA_and_ARMv7_10.0.3_150403.zip
and I should see both:
Eclipse Freescale Solutions Category
QorIQ Configuration and Validation Suite 4.2.0
I only see the QorIQ software.
Anyone know where to get the updater tools?
-jjh
You have to use http://freescale.com/lgfiles/updates/Eclipse/QCVS as update site. The packages for CodeWarrior doesn't contain the Eclipse Freescale Updater, because this action is already included in CodeWarrior.
Adrian
Adrian,
I had tried that site while in the office last night and it could not be found. I think I had some kind of proxy issue because I tried it from home this morning and it worked.
I had access to the solutions group. But after installing the solutions tools, restarting Eclipse and then installing the QorIQ tool, I got errors deep in the install.
I came back in the office where I downloaded the QorIQ tools and tried the install from the local copy and that just now completed successfully.
I asked tech support to check out the network install errors and also figure out why the Eclipse Freescale Solutions Category doesn’t come with the QorIQ download.
Maybe have a separate download for it like the separate the PA and ARM tools.
-jjh
On a stock eclipse you should see:
For installing over CodeWarrior for PA or ARMv7, on freescale.com are available offline installation packages or also the update site.
Adrian
