Newbie tutorials for Codewarrior and ColdFire Lite
2,774 次查看
MikeMiller
I am using CodeWarrior 6.3 to develop an application using the ColdFire Lite TCP/IP stack fro InterNiche on a MCF52233DEMO board.
Are there any simple tutorials for CodeWarrior explaining how to add the ColdFire Lite code to my project?
Thanks and best regards,
Mike.
标签 (1)
标记 (1)
2 回复数
1,333 次查看
J2MEJediMaster
Specialist I
Assuming you already have a CodeWarrior project with your code in it:
1) Mouse-click on the folder with the ColdFire Lite and drag it to CodeWarrior's project window.
2) You should get an Add Files dialog asking you what targets to add the ColdFire Lite code to. Checkbox the appropriate targets and click OK.
3)You'll get a Project messages window that explains that access paths to the Coldfire Lite folder have been added to the project.
4) Use the target column in the project window to deselect the ColdFire Lite files that you don't want to be part of the build.
I'm not familiar with ColdFire Lite, so I can only explain the procedure in general terms.
---Tom
Message Edited by J2MEJediMaster on 2007-01-31 10:11 AM
1,333 次查看
MikeMiller
Many thanks JediMaster. That is exactly the answer I needed.
Mike
