MPC5121 can't write to memory,and unable to function properly.
2,679 次查看
hensonJhon
The DDR model used is EM68C08CWAG-25H, and the register values can be read correctly in codewarrior. when debugging the program, the program will be stuck at 0x00000800 and can NOT run forward.
About the .cfg I used the codewarrior 9.2 file like(DIR\Freescale\CodeWarrior for MobileGT V9.2\PowerPC_EABI_Support\Initialization_Files\52xx\5121ADS_init.cfg).
but it also does not work.
help!!
标记 (2)
1 回复
2,652 次查看
davidtosenovjan
Hi, I'm afraid we don't currently have a support specialist for this older MPC5121 device.
I'm sorry, but we can't help you, except maybe another community user can help. Thanks for understanding.
