Linker errors in std::tr1::shared_ptr destructor
cw_Potz
Hi All,
I ran into some strange linker errors while building a project comprising both C and C++ files. I am using MSL (Metrowerks Standard Libraries) in my project.
I am using PowerPC EABI Linker. Version: Code Warrior PowerPC ISA, Release 8.5 Build 50425
Processor: 827x
Linker error:
Link Error : undefined: 'std::tr1::detail::shared_ptr_deleter_common::release()'
Referenced from 'std::tr1::shared_ptr<char>::~shared_ptr()'
Any ideas about this error ?? I googled and all the discussions were about macintosh and CW version 9.1. But I am using windows and CW version 8.5.
Thanks in advance !!
CrasyCat
Specialist III
Hello
   Just mw 2 cents on this one.
   Did you link the C++ libraries with your application? Did you specify you wanted to use C++ as
   programming language when you created the project?
CrasyCat
