LX2160ARDB: DDR validation
Priyaa
We have loaded the RCW file(rcw_2200_750_2900_19_5_2.bin) from the LSDK into SD card and in DDR configuration panel, when Read SPD is done we are getting as "Unsupported raw card revision. Set the CLK to DQS skew values manually."
How to perform DDR validation of LX2160ARDB in QCVS tool
Priyaa
Hi June Lu,
To boot the LX2160ARDB from SD card is DDR register values has to be modified in the u-boot source or it reads from SPD of DIMMs?
Kindly clarify...thank you
June_Lu
For the standard LX2160ARDB with DIMM slots, DDR registers are configured automatically by reading SPD from the installed DIMMs — handled by the TF-A BL2 stage (ddr_init.c), not U-Boot. You only need to modify the ATF source if using custom DIMMs on the LX2160ARDB.
If there are any new questions, please create a new thread so we can track them properly, as this case has been inactive for quite some time.
Thanks.
Priyaa
Hi June Lu,
After changing the switch(SW1) to SD card mode where the RCW source is present, we were able to do the validation.
Thanks for the support..
June_Lu
It looks like you were able to read the SPD successfully, although the screenshot is slightly different from what I see on my side.
Please set SW1[1:4] to 1001 to boot from eMMC, where the RCW source has been configured for DDR validation.
Also, please confirm that "Target Connects" shows as connected see the screen shot.
Once confirmed, you can proceed with the DDR validation.
Priyaa
Hi June Lu,
Following the user guide, created a project again for DDR configuration and reading of SPD has done as below
And the DIMM modules are inserted in the J14, J17 connectors of RDB
June_Lu
It seem your screen shot is not same as me, missing button "Back" and "Cancel".
Have you follow the QCVS_DDR_User_Guide, 1.1.1 Using DDR configuration tool?
Priyaa
Diagnose Connection successfully done
And DDR configuration after reading SPD is as below
Could you please confirm whether DDR validation is started successully?
Cause I'm facing an issue that the Start Validation button is enabled but the validation getting cancelled just after the start..
June_Lu
This is the successful screenshot.
I used the USB to connect to the CWTAP. You need to set the Probe with correct IP address.
Could you run the "Diagnose Connection" successfully?
Priyaa
Hi June Lu,
Connected through ethernet and able to find LX2160A as provided in the text file
But reading SPD gives as "Unsupported raw card revision. Set the CLK to DQS skew values manually." in DDR configuration window
And how to verify the SPD values are read successfully?
June_Lu
(bin) 50 % delete all
(bin) 51 % config cc cwtap:10.1.66.150
(bin) 52 % show cc
(bin) 53 % source IDcode.tcl
If you could find LX2160A same as the "CCS Windows Release Build 503.0.0.220812-p0.txt".
You could proceed using ethernet connection with IP address: 10.1.66.150 for ddr validation.
Priyaa
Hi June Lu,
for USB the result of the command is
(bin) 51 % findcc cwtaps
0
(bin) 51 %
and for ethernet connection
FSL07E3D5 (10.1.66.150): CodeWarrior TAP v2
Cortex-10 Probe Tip
Boot Loader v1.0.1
Operating System v1.0.5
1
for now can we proceed further using ethernet connection for ddr validation?
June_Lu
(bin) 52 % show cc
0: USB open failure
There are no command converters configured
it indicates that the CWTAP cannot be detected through the USB connection.
Please check the USB cable connection and ensure the CWTAP is properly recognized by the host PC.
Also, please run the command below and share the result:
(bin) 6 % findcc cwtaps
Thanks.
Priyaa
Hi June Lu,
CodeWarrior Version-
(bin) 49 % log v
CCS Linux Release Build 503.0.0.220812-p0
verbose logging
(bin) 52 % show cc
0: USB open failure
(bin) 53 %
Scanning for available TAPs connected via USB.....
No TAPs found connected via USB
+ Available Remote Connections
+ 1 - CodeWarriorTAP - <Specify IP Address>
+ 2 - GigabitTAP - <Specify IP Address>
+ x - Exit Script without Changes
Specify connection:
can't read "CONNECTION()": no such element in array
(bin) 54 %
(bin) 54 %
Able to connect through ethernet and ping the target. Even after updating CodeWarrior to v11.5.12, reading SPD gives same as "Unsupported raw card revision. Set the CLK to DQS skew values manually."
Thank you
June_Lu
Please confirm the CodeWarrior version from Help → About CodeWarrior Development Studio for QorIQ LS Series (ARM v8 ISA).
Please follow the instructions in "CCS Windows Release Build 503.0.0.220812-p0.txt" to verify the connection status.
We recommend testing the USB connection first, followed by the Ethernet connection.
It seems that the IP address has changed. Could you please confirm whether you can successfully ping the target?
Priyaa
Hi June Lu,
We are using CodeWarrior 11.5.0 and the DIMM is original module given with the LX2160ARDB
Updated CodeWarrior with archive com.freescale.armv8.11.5.12.GA.Lin.updatesite.221209.zip for v11.5.12
Now unable to detect the JTAG
Thankyou
June_Lu
I followed your sequence and was able to read the SPD successfully.
Could you please confirm which version of CodeWarrior you are using? Is it CodeWarrior 11.5.12?
Also, is the DIMM an original module?
Thanks.
Priyaa
Hi June Lu,
After booting through FlexSPI, loaded the RCW file through tftpboot at u-boot and mmc write commands as below
=> tftpboot 0x90000000 rcw_2200_750_2900_19_5_2.bin
=> mmc dev 0; mmc write 0x90000000 8 1
=> qixis_reset sd (during this command the D19 got turned on and off)
And for DDR configuration, when reading from SPD getting as "Unsupported raw card revision. Set the CLK to DQS skew values manually."
June_Lu
How do you load the RCW file(rcw_2200_750_2900_19_5_2.bin) from the LSDK into SD card?
Has the D19 turned on and off?
DDR validation of LX2160ARDB in QCVS tool, you could refer to:
QCVS_DDR_User_Guide
%3CLINGO-SUB%20id%3D%22lingo-sub-2410373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20have%20loaded%20the%20RCW%20file(rcw_2200_750_2900_19_5_2.bin)%20from%20the%20LSDK%20into%20SD%20card%20and%20in%20DDR%20configuration%20panel%2C%20when%20%3CSTRONG%3ERead%20SPD%3C%2FSTRONG%3E%20is%20done%20we%20are%20getting%20as%3CSTRONG%3E%20%22Unsupported%20raw%20card%20revision.%20Set%20the%20CLK%20to%20DQS%20skew%20values%20manually.%22%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHow%20to%20perform%20DDR%20validation%20of%20LX2160ARDB%20in%20QCVS%20tool%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395756i5C2639307B7D9623%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788337942087.png%22%20alt%3D%22Priyaa_0-1788337942087.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CP%3EThanks%20for%20the%20support%3C%2FP%3E%3CP%3Efor%20USB%20the%20result%20of%20the%20command%20is%3C%2FP%3E%3CP%3E(bin)%2051%20%25%20findcc%20cwtaps%3CBR%20%2F%3E0%3CBR%20%2F%3E(bin)%2051%20%25%3CBR%20%2F%3E%3CBR%20%2F%3Eand%20for%20ethernet%20connection%3C%2FP%3E%3CP%3E(bin)%2051%20%25%20findcc%20cwtaps%3CBR%20%2F%3EFSL07E3D5%20(10.1.66.150)%3A%20CodeWarrior%20TAP%20v2%3CBR%20%2F%3ECortex-10%20Probe%20Tip%3CBR%20%2F%3EBoot%20Loader%20v1.0.1%3CBR%20%2F%3EOperating%20System%20v1.0.5%3CBR%20%2F%3E1%3CBR%20%2F%3E%3CBR%20%2F%3Efor%20now%20can%20we%20proceed%20further%20using%20ethernet%20connection%20for%20ddr%20validation%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2052%20%25%20show%20cc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E0%3A%20USB%20open%20failure%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EThere%20are%20no%20command%20converters%20configured%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3Eit%20indicates%20that%20the%20CWTAP%20cannot%20be%20detected%20through%20the%20USB%20connection.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EPlease%20check%20the%20USB%20cable%20connection%20and%20ensure%20the%20CWTAP%20is%20properly%20recognized%20by%20the%20host%20PC.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EAlso%2C%20please%20run%20the%20command%20below%20and%20share%20the%20result%3A%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%206%20%25%20findcc%20cwtaps%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CP%3ECodeWarrior%20Version-%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395821i12F705AF843C5DC3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788417354430.png%22%20alt%3D%22Priyaa_0-1788417354430.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E(bin)%2049%20%25%20log%20v%3CBR%20%2F%3ECCS%20Linux%20Release%20Build%20503.0.0.220812-p0%3CBR%20%2F%3Everbose%20logging%3CBR%20%2F%3E(bin)%2050%20%25%20delete%20all%3CBR%20%2F%3E(bin)%2051%20%25%20config%20cc%20cwtap%3CBR%20%2F%3E(bin)%2052%20%25%20show%20cc%3CBR%20%2F%3E0%3A%20USB%20open%20failure%3CBR%20%2F%3EThere%20are%20no%20command%20converters%20configured%3CBR%20%2F%3E(bin)%2053%20%25%3CBR%20%2F%3E(bin)%2053%20%25%20source%20IDcode.tcl%3C%2FP%3E%3CP%3EScanning%20for%20available%20TAPs%20connected%20via%20USB.....%3C%2FP%3E%3CP%3ENo%20TAPs%20found%20connected%20via%20USB%3C%2FP%3E%3CP%3E%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20Available%20Remote%20Connections%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%201%20-%20CodeWarriorTAP%20-%20%3CSPECIFY%20ip%3D%22%22%20address%3D%22%22%3E%3CBR%20%2F%3E%2B%202%20-%20GigabitTAP%20-%20%3CSPECIFY%20ip%3D%22%22%20address%3D%22%22%3E%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20x%20-%20Exit%20Script%20without%20Changes%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3C%2FSPECIFY%3E%3C%2FSPECIFY%3E%3C%2FP%3E%3CP%3ESpecify%20connection%3A%3C%2FP%3E%3CP%3Ecan't%20read%20%22CONNECTION()%22%3A%20no%20such%20element%20in%20array%3CBR%20%2F%3E(bin)%2054%20%25%3CBR%20%2F%3E(bin)%2054%20%25%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EAble%20to%20connect%20through%20ethernet%20and%20ping%20the%20target.%20Even%20after%20updating%20CodeWarrior%20to%20v11.5.12%2C%20reading%20SPD%20gives%20same%20as%20%3CSTRONG%3E%22Unsupported%20raw%20card%20revision.%20Set%20the%20CLK%20to%20DQS%20skew%20values%20manually.%22%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EPlease%20confirm%20the%20CodeWarrior%20version%20from%20Help%20%E2%86%92%20About%20CodeWarrior%20Development%20Studio%20for%20QorIQ%20LS%20Series%20(ARM%20v8%20ISA).%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EPlease%20follow%20the%20instructions%20in%20%22CCS%20Windows%20Release%20Build%20503.0.0.220812-p0.txt%22%20to%20verify%20the%20connection%20status.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EWe%20recommend%20testing%20the%20USB%20connection%20first%2C%20followed%20by%20the%20Ethernet%20connection.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EIt%20seems%20that%20the%20IP%20address%20has%20changed.%20Could%20you%20please%20confirm%20whether%20you%20can%20successfully%20ping%20the%20target%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20are%20using%20CodeWarrior%2011.5.0%20and%20the%20DIMM%20is%20original%20module%20given%20with%20the%20LX2160ARDB%3C%2FP%3E%3CP%3EUpdated%20CodeWarrior%20with%20archive%20%3CSTRONG%3Ecom.freescale.armv8.11.5.12.GA.Lin.updatesite.221209.zip%26nbsp%3B%3C%2FSTRONG%3Efor%20v11.5.12%3CBR%20%2F%3E%3CBR%20%2F%3ENow%20unable%20to%20detect%20the%20JTAG%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395817i009D153A8B74B697%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788412965825.png%22%20alt%3D%22Priyaa_0-1788412965825.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThankyou%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EI%20followed%20your%20sequence%20and%20was%20able%20to%20read%20the%20SPD%20successfully.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3ECould%20you%20please%20confirm%20which%20version%20of%20CodeWarrior%20you%20are%20using%3F%20Is%20it%20CodeWarrior%2011.5.12%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EAlso%2C%20is%20the%20DIMM%20an%20original%20module%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAfter%20booting%20through%20FlexSPI%2C%20loaded%20the%20RCW%20file%20through%20tftpboot%20at%20u-boot%20and%20mmc%20write%20commands%20as%20below%3C%2FP%3E%3CP%3E%3D%26gt%3B%20tftpboot%26nbsp%3B0x90000000%20rcw_2200_750_2900_19_5_2.bin%3C%2FP%3E%3CP%3E%3D%26gt%3B%20mmc%20dev%200%3B%20mmc%20write%200x90000000%208%201%3C%2FP%3E%3CP%3E%3D%26gt%3B%20qixis_reset%20sd%20(during%20this%20command%20the%20D19%20got%20turned%20on%20and%20off)%3C%2FP%3E%3CP%3EAnd%20for%20DDR%20configuration%2C%20when%20reading%20from%20SPD%20getting%20as%3CSTRONG%3E%20%22Unsupported%20raw%20card%20revision.%20Set%20the%20CLK%20to%20DQS%20skew%20values%20manually.%22%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EHow%20do%20you%20load%20the%20RCW%20file(rcw_2200_750_2900_19_5_2.bin)%20from%20the%20LSDK%20into%20SD%20card%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EHas%20the%20D19%20turned%20on%20and%20off%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EDDR%20validation%20of%20LX2160ARDB%20in%20QCVS%20tool%2C%20you%20could%20refer%20to%3A%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FQCVS_DDR_User_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQCVS_DDR_User_Guide%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDiagnose%20Connection%20successfully%20done%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395861i9A454883E79E4FD2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788431456696.png%22%20alt%3D%22Priyaa_0-1788431456696.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAnd%20DDR%20configuration%20after%20reading%20SPD%20is%20as%20below%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395862iA9869BFA5AAA9AF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_1-1788432417841.png%22%20alt%3D%22Priyaa_1-1788432417841.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECould%20you%20please%20confirm%20whether%20DDR%20validation%20is%20started%20successully%3F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ECause%20I'm%20facing%20an%20issue%20that%20the%20%3CSTRONG%3EStart%20Validation%26nbsp%3B%3C%2FSTRONG%3Ebutton%20is%20enabled%20but%20the%20validation%20getting%20cancelled%20just%20after%20the%20start..%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CP%3EConnected%20through%20ethernet%20and%20able%20to%20find%20LX2160A%20as%20provided%20in%20the%20text%20file%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395851iD9B702C2E55E4D86%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788427814124.png%22%20alt%3D%22Priyaa_0-1788427814124.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBut%20reading%20SPD%20gives%20as%20%3CSTRONG%3E%22Unsupported%20raw%20card%20revision.%20Set%20the%20CLK%20to%20DQS%20skew%20values%20manually.%22%26nbsp%3B%3C%2FSTRONG%3Ein%20DDR%20configuration%20window%3CBR%20%2F%3E%3CBR%20%2F%3EAnd%20how%20to%20verify%20the%20SPD%20values%20are%20read%20successfully%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20the%20successful%20screenshot.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395858iB3521AA7CCD68CF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22June_Lu_0-1788429917395.png%22%20alt%3D%22June_Lu_0-1788429917395.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EI%20used%20the%20USB%20to%20connect%20to%20the%20CWTAP.%20You%20need%20to%20set%20the%20Probe%20with%20correct%20IP%20address.%3C%2FP%3E%0A%3CP%3ECould%20you%20run%20the%20%22Diagnose%20Connection%22%20successfully%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395859i847710DD679B8214%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22June_Lu_1-1788430165643.png%22%20alt%3D%22June_Lu_1-1788430165643.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2050%20%25%20delete%20all%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2051%20%25%20config%20cc%20cwtap%3A10.1.66.150%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2052%20%25%20show%20cc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2053%20%25%20source%20IDcode.tcl%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EIf%20you%20could%20find%20LX2160A%20same%20as%20the%20%22CCS%20Windows%20Release%20Build%20503.0.0.220812-p0.txt%22.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EYou%20could%20proceed%20using%20ethernet%20connection%20with%20IP%20address%3A%2010.1.66.150%20for%20ddr%20validation.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFollowing%20the%20user%20guide%2C%20created%20a%20project%20again%20for%20DDR%20configuration%20and%20reading%20of%20SPD%20has%20done%20as%20below%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395901i673CEA81ECBDB4C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788498272408.png%22%20alt%3D%22Priyaa_0-1788498272408.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAnd%20the%20DIMM%20modules%20are%20inserted%20in%20the%20J14%2C%20J17%20connectors%20of%20RDB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAfter%20changing%20the%20switch(SW1)%20to%20SD%20card%20mode%20where%20the%20RCW%20source%20is%20present%2C%20we%20were%20able%20to%20do%20the%20validation.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20for%20the%20support..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EIt%20seem%20your%20screen%20shot%20is%20not%20same%20as%20me%2C%20missing%20button%20%22Back%22%20and%20%22Cancel%22.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EHave%20you%20follow%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FQCVS_DDR_User_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQCVS_DDR_User_Guide%3C%2FA%3E%2C%201.1.1%20Using%20DDR%20configuration%20tool%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EIt%20looks%20like%20you%20were%20able%20to%20read%20the%20SPD%20successfully%2C%20although%20the%20screenshot%20is%20slightly%20different%20from%20what%20I%20see%20on%20my%20side.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EPlease%20set%20SW1%5B1%3A4%5D%20to%201001%20to%20boot%20from%20eMMC%2C%20where%20the%20RCW%20source%20has%20been%20configured%20for%20DDR%20validation.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EAlso%2C%20please%20confirm%20that%20%22Target%20Connects%22%20shows%20as%20connected%20see%20the%20screen%20shot.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EOnce%20confirmed%2C%20you%20can%20proceed%20with%20the%20DDR%20validation.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395908i184EA8655F628043%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22June_Lu_0-1788504721222.png%22%20alt%3D%22June_Lu_0-1788504721222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788504721222.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20June%20Lu%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ETo%20boot%20the%20LX2160ARDB%20from%20SD%20card%20is%20DDR%20register%20values%20has%20to%20be%20modified%20in%20the%20u-boot%20source%20or%20it%20reads%20from%20SPD%20of%20DIMMs%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKindly%20clarify...thank%20you%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
