LX2160ARDB: DDR validation
1,432件の閲覧回数
Priyaa
We have loaded the RCW file(rcw_2200_750_2900_19_5_2.bin) from the LSDK into SD card and in DDR configuration panel, when Read SPD is done we are getting as "Unsupported raw card revision. Set the CLK to DQS skew values manually."
How to perform DDR validation of LX2160ARDB in QCVS tool
タグ(1)
18 返答(返信)
640件の閲覧回数
Priyaa
Hi June Lu,
To boot the LX2160ARDB from SD card is DDR register values has to be modified in the u-boot source or it reads from SPD of DIMMs?
Kindly clarify...thank you
506件の閲覧回数
June_Lu
For the standard LX2160ARDB with DIMM slots, DDR registers are configured automatically by reading SPD from the installed DIMMs — handled by the TF-A BL2 stage (ddr_init.c), not U-Boot. You only need to modify the ATF source if using custom DIMMs on the LX2160ARDB.
If there are any new questions, please create a new thread so we can track them properly, as this case has been inactive for quite some time.
Thanks.
1,245件の閲覧回数
Priyaa
Hi June Lu,
After changing the switch(SW1) to SD card mode where the RCW source is present, we were able to do the validation.
Thanks for the support..
1,256件の閲覧回数
June_Lu
It looks like you were able to read the SPD successfully, although the screenshot is slightly different from what I see on my side.
Please set SW1[1:4] to 1001 to boot from eMMC, where the RCW source has been configured for DDR validation.
Also, please confirm that "Target Connects" shows as connected see the screen shot.
Once confirmed, you can proceed with the DDR validation.
1,266件の閲覧回数
Priyaa
Hi June Lu,
Following the user guide, created a project again for DDR configuration and reading of SPD has done as below
And the DIMM modules are inserted in the J14, J17 connectors of RDB
1,269件の閲覧回数
June_Lu
It seem your screen shot is not same as me, missing button "Back" and "Cancel".
Have you follow the QCVS_DDR_User_Guide, 1.1.1 Using DDR configuration tool?
1,317件の閲覧回数
Priyaa
Diagnose Connection successfully done
And DDR configuration after reading SPD is as below
Could you please confirm whether DDR validation is started successully?
Cause I'm facing an issue that the Start Validation button is enabled but the validation getting cancelled just after the start..
1,327件の閲覧回数
June_Lu
This is the successful screenshot.
I used the USB to connect to the CWTAP. You need to set the Probe with correct IP address.
Could you run the "Diagnose Connection" successfully?
1,332件の閲覧回数
Priyaa
Hi June Lu,
Connected through ethernet and able to find LX2160A as provided in the text file
But reading SPD gives as "Unsupported raw card revision. Set the CLK to DQS skew values manually." in DDR configuration window
And how to verify the SPD values are read successfully?
1,333件の閲覧回数
June_Lu
(bin) 50 % delete all
(bin) 51 % config cc cwtap:10.1.66.150
(bin) 52 % show cc
(bin) 53 % source IDcode.tcl
If you could find LX2160A same as the "CCS Windows Release Build 503.0.0.220812-p0.txt".
You could proceed using ethernet connection with IP address: 10.1.66.150 for ddr validation.
1,345件の閲覧回数
Priyaa
Hi June Lu,
for USB the result of the command is
(bin) 51 % findcc cwtaps
0
(bin) 51 %
and for ethernet connection
FSL07E3D5 (10.1.66.150): CodeWarrior TAP v2
Cortex-10 Probe Tip
Boot Loader v1.0.1
Operating System v1.0.5
1
for now can we proceed further using ethernet connection for ddr validation?
1,349件の閲覧回数
June_Lu
(bin) 52 % show cc
0: USB open failure
There are no command converters configured
it indicates that the CWTAP cannot be detected through the USB connection.
Please check the USB cable connection and ensure the CWTAP is properly recognized by the host PC.
Also, please run the command below and share the result:
(bin) 6 % findcc cwtaps
Thanks.
1,355件の閲覧回数
Priyaa
Hi June Lu,
CodeWarrior Version-
(bin) 49 % log v
CCS Linux Release Build 503.0.0.220812-p0
verbose logging
(bin) 52 % show cc
0: USB open failure
(bin) 53 %
Scanning for available TAPs connected via USB.....
No TAPs found connected via USB
+ Available Remote Connections
+ 1 - CodeWarriorTAP - <Specify IP Address>
+ 2 - GigabitTAP - <Specify IP Address>
+ x - Exit Script without Changes
Specify connection:
can't read "CONNECTION()": no such element in array
(bin) 54 %
(bin) 54 %
Able to connect through ethernet and ping the target. Even after updating CodeWarrior to v11.5.12, reading SPD gives same as "Unsupported raw card revision. Set the CLK to DQS skew values manually."
Thank you
1,358件の閲覧回数
June_Lu
Please confirm the CodeWarrior version from Help → About CodeWarrior Development Studio for QorIQ LS Series (ARM v8 ISA).
Please follow the instructions in "CCS Windows Release Build 503.0.0.220812-p0.txt" to verify the connection status.
We recommend testing the USB connection first, followed by the Ethernet connection.
It seems that the IP address has changed. Could you please confirm whether you can successfully ping the target?
1,366件の閲覧回数
Priyaa
Hi June Lu,
We are using CodeWarrior 11.5.0 and the DIMM is original module given with the LX2160ARDB
Updated CodeWarrior with archive com.freescale.armv8.11.5.12.GA.Lin.updatesite.221209.zip for v11.5.12
Now unable to detect the JTAG
Thankyou
1,369件の閲覧回数
June_Lu
I followed your sequence and was able to read the SPD successfully.
Could you please confirm which version of CodeWarrior you are using? Is it CodeWarrior 11.5.12?
Also, is the DIMM an original module?
Thanks.
1,397件の閲覧回数
Priyaa
Hi June Lu,
After booting through FlexSPI, loaded the RCW file through tftpboot at u-boot and mmc write commands as below
=> tftpboot 0x90000000 rcw_2200_750_2900_19_5_2.bin
=> mmc dev 0; mmc write 0x90000000 8 1
=> qixis_reset sd (during this command the D19 got turned on and off)
And for DDR configuration, when reading from SPD getting as "Unsupported raw card revision. Set the CLK to DQS skew values manually."
タグ(1)
1,412件の閲覧回数
June_Lu
How do you load the RCW file(rcw_2200_750_2900_19_5_2.bin) from the LSDK into SD card?
Has the D19 turned on and off?
DDR validation of LX2160ARDB in QCVS tool, you could refer to:
QCVS_DDR_User_Guide
%3CLINGO-SUB%20id%3D%22lingo-sub-2410373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2160ARDB%3A%20DDR%E6%A4%9C%E8%A8%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ELSDK%E3%81%8B%E3%82%89RCW%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88rcw_2200_750_2900_19_5_2.bin%EF%BC%89%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81DDR%E6%A7%8B%E6%88%90%E3%83%91%E3%83%8D%E3%83%AB%E3%81%A7%3CSTRONG%3ERead%20SPD%3C%2FSTRONG%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%20%3CSTRONG%3E%E3%80%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%94%9F%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82CLK%E3%82%92DQS%E3%82%B9%E3%82%AD%E3%83%A5%E3%83%BC%E5%80%A4%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EQCVS%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7LX2160ARDB%E3%81%AEDDR%E6%A4%9C%E8%A8%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788337942087.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395756i5C2639307B7D9623%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788337942087.png%22%20alt%3D%22Priyaa_0-1788337942087.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788337942087.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EUSB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF%3C%2FP%3E%3CP%3E(%E3%83%93%E3%83%B3)51%25%20findcc%20cwtaps%3CBR%20%2F%3E0%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)51%25%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E7%94%A8%3C%2FP%3E%3CP%3E(bin)%2051%25%20findcc%20cwtaps%3CBR%20%2F%3E%20FSL07E3D5%20(10.1.66.150)%3ACodeWarrior%20TAP%20v2%3CBR%20%2F%3ECortex-10%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%81%E3%83%83%E3%83%97%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%20v1.0.1%3CBR%20%2F%3E%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20v1.0.5%3CBR%20%2F%3E1%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81DDR%E6%A4%9C%E8%A8%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E9%80%B2%E3%82%81%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%EF%BC%88%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%EF%BC%8952%EF%BC%85%E8%A1%A8%E7%A4%BAcc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E0%3A%20USB%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81CWTAP%E3%81%8CUSB%E6%8E%A5%E7%B6%9A%E3%81%8B%E3%82%89%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81CWTAP%E3%81%8C%E3%83%9B%E3%82%B9%E3%83%88PC%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E7%B5%90%E6%9E%9C%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%206%25%20findcc%20cwtaps%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3ECodeWarrior%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3-%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788417354430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395821i12F705AF843C5DC3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788417354430.png%22%20alt%3D%22Priyaa_0-1788417354430.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788417354430.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E(%E3%83%93%E3%83%B3)49%25%20log%20v%3CBR%20%2F%3ECCS%20Linux%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%93%E3%83%AB%E3%83%89%20503.0.0.220812-p0%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%83%AD%E3%82%B0%E8%A8%98%E9%8C%B2%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)50%25%E5%85%A8%E3%81%A6%E5%89%8A%E9%99%A4%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)51%25%E6%A7%8B%E6%88%90CC%E3%81%AECWTAP%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)52%25%E3%80%81CC%E3%82%92%E8%A1%A8%E7%A4%BA%3CBR%20%2F%3E0%3A%20USB%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)53%25%3CBR%20%2F%3E(bin)%2053%25%20source%20IDcode.tcl(bin)%3C%2FP%3E%3CP%3EUSB%E6%8E%A5%E7%B6%9A%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AATAP%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99.....%3C%2FP%3E%3CP%3EUSB%E6%8E%A5%E7%B6%9A%E3%81%AETAP%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E6%8E%A5%E7%B6%9A%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%201%20-%20CodeWarriorTAP%20-%3CSPECIFY%20ip%3D%22%22%20address%3D%22%22%3E%3CBR%20%2F%3E%20%2B%202%20-%20GigabitTAP%20-%3CSPECIFY%20ip%3D%22%22%20address%3D%22%22%3E%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%20x%20-%20%E5%A4%89%E6%9B%B4%E3%81%9B%E3%81%9A%E3%81%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E7%B5%82%E4%BA%86%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3C%2FSPECIFY%3E%3C%2FSPECIFY%3E%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FP%3E%3CP%3E%E3%80%8CCONNECTION()%E3%80%8D%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%E9%85%8D%E5%88%97%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A6%81%E7%B4%A0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)54%25%3CBR%20%2F%3E(%E3%83%93%E3%83%B3)54%25%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%ABping%E3%82%92%E9%80%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82CodeWarrior%E3%82%92v11.5.12%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%82%82%E3%80%81SPD%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%99%82%3CSTRONG%3E%E3%81%AB%E3%80%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%94%9F%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82CLK%E3%82%92DQS%E3%82%B9%E3%82%AD%E3%83%A5%E3%83%BC%E5%80%A4%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%3C%2FSTRONG%3E%E3%81%A8%E3%81%84%E3%81%86%E5%90%8C%E3%81%98%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3ECodeWarrior%E7%89%88%E3%81%AF%E3%80%81QorIQ%20LS%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA(ARM%20v8%20ISA)%E5%90%91%E3%81%91CodeWarrior%E9%96%8B%E7%99%BA%E3%82%B9%E3%82%BF%E3%82%B8%E3%82%AA%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6Help%20%E2%86%92%E3%81%8B%E3%82%89%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E6%8E%A5%E7%B6%9A%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8CCCS%20Windows%20Release%20Build%20503.0.0.220812-p0.txt%E3%80%8D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%BE%E3%81%9AUSB%E6%8E%A5%E7%B6%9A%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E3%81%99%E3%81%99%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%ABping%E3%81%8C%E5%B1%8A%E3%81%8F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECodeWarrior%2011.5.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81DIMM%E3%81%AFLX2160ARDB%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E7%B4%94%E6%AD%A3%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECodeWarrior%E3%82%92%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%3CSTRONG%3Ecom.freescale.armv8.11.5.12.GA.Lin.updatesite.221209.zip%3C%2FSTRONG%3E%E3%81%A7%E6%9B%B4%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B311.5.12%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%3CBR%20%2F%3EJTAG%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788412965825.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395817i009D153A8B74B697%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788412965825.png%22%20alt%3D%22Priyaa_0-1788412965825.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788412965825.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8C%87%E7%A4%BA%E9%80%9A%E3%82%8A%E3%81%AB%E6%93%8D%E4%BD%9C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81SPD%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AECodeWarrior%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FCodeWarrior%2011.5.12%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%81%AEDIMM%E3%81%AF%E7%B4%94%E6%AD%A3%E5%93%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFlexSPI%E7%B5%8C%E7%94%B1%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81u-boot%E3%81%A7tftpboot%E7%B5%8C%E7%94%B1%E3%81%A7RCW%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEmmc%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3D%26gt%3B%20tftpboot%26nbsp%3B0x90000000%20rcw_2200_750_2900_19_5_2.bin%3C%2FP%3E%3CP%3E%3D%26gt%3B%20mmc%20dev%200%3B%20mmc%20write%200x90000000%208%201%3C%2FP%3E%3CP%3E%3D%26gt%3B%20qixis_reset%20sd%20(%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%ABD19%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%95%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81DDR%E6%A7%8B%E6%88%90%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81SPD%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%3CSTRONG%3E%E3%80%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%94%9F%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82CLK%E3%82%92DQS%E3%82%B9%E3%82%AD%E3%83%A5%E3%83%BC%E5%80%A4%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3ELSDK%E3%81%8B%E3%82%89RCW%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88rcw_2200_750_2900_19_5_2.bin%EF%BC%89%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3ED19%E3%81%AF%E9%9B%BB%E6%BA%90%E3%81%AE%E3%82%AA%E3%83%B3%E3%82%AA%E3%83%95%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EQCVS%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AEDDR%E3%81%AELX2160ARDB%E6%A4%9C%E8%A8%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FQCVS_DDR_User_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQCVS_DDR_%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%80%9A%E3%82%8ALX2160A%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788427814124.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395851iD9B702C2E55E4D86%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788427814124.png%22%20alt%3D%22Priyaa_0-1788427814124.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788427814124.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81DDR%E8%A8%AD%E5%AE%9A%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7SPD%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%3CSTRONG%3E%E3%80%81%E3%80%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%94%9F%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82CLK%E3%82%92DQS%E3%82%B9%E3%82%AD%E3%83%A5%E3%83%BC%E5%80%A4%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%3C%2FSTRONG%3E%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20SPD%E5%80%A4%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2050%25%E3%81%99%E3%81%B9%E3%81%A6%E5%89%8A%E9%99%A4%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2051%20%25%20config%20cc%20cwtap%3A10.1.66.150%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%EF%BC%88%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%EF%BC%8952%EF%BC%85%E8%A1%A8%E7%A4%BAcc%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E(bin)%2053%25%20%E3%82%BD%E3%83%BC%E3%82%B9%20IDcode.tcl%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%82%82%E3%81%97%E3%80%8CCCS%20Windows%20Release%20Build%20503.0.0.220812-p0.txt%E3%80%8D%E3%81%A8%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8C%E3%81%B0LX2160A%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EDDR%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%81%AB%E3%81%AFIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B910.1.66.150%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BD%BF%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E6%88%90%E5%8A%9F%E6%99%82%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788429917395.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395858iB3521AA7CCD68CF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22June_Lu_0-1788429917395.png%22%20alt%3D%22June_Lu_0-1788429917395.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788429917395.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EUSB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6CWTAP%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%80%8C%E6%8E%A5%E7%B6%9A%E8%A8%BA%E6%96%AD%E3%80%8D%E3%82%92%E6%88%90%E5%8A%9F%E8%A3%8F%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_1-1788430165643.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395859i847710DD679B8214%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22June_Lu_1-1788430165643.png%22%20alt%3D%22June_Lu_1-1788430165643.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_1-1788430165643.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E8%A8%BA%E6%96%AD%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788431456696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395861i9A454883E79E4FD2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788431456696.png%22%20alt%3D%22Priyaa_0-1788431456696.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788431456696.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESPD%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%BE%8C%E3%81%AEDDR%E6%A7%8B%E6%88%90%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_1-1788432417841.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395862iA9869BFA5AAA9AF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_1-1788432417841.png%22%20alt%3D%22Priyaa_1-1788432417841.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_1-1788432417841.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDDR%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%81%8C%E9%A0%86%E8%AA%BF%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%82%82%3CSTRONG%3E%E3%80%81%E6%A4%9C%E8%A8%BC%E9%96%8B%E5%A7%8B%3C%2FSTRONG%3E%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%A4%9C%E8%A8%BC%E9%96%8B%E5%A7%8B%E7%9B%B4%E5%BE%8C%E3%81%AB%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%E5%86%8D%E3%81%B3DDR%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8SPD%E3%81%AE%E8%AA%AD%E3%81%BF%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Priyaa_0-1788498272408.png%22%20style%3D%22width%3A%20299px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395901i673CEA81ECBDB4C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Priyaa_0-1788498272408.png%22%20alt%3D%22Priyaa_0-1788498272408.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPriyaa_0-1788498272408.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDIMM%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AFRDB%E3%81%AEJ14%E3%80%81J17%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AF%E7%A7%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%80%8C%E6%88%BB%E3%82%8B%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%A8%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%AB%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FQCVS_DDR_User_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQCVS_DDR_User_Guide%3C%2FA%3E%201.1.1%20%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9FDDR%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81(SW1)%E3%82%92RCW%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8BSD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E6%A4%9C%E8%A8%BC%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3ESPD%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AF%E7%A7%81%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E8%8B%A5%E5%B9%B2%E7%95%B0%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3EDDR%E6%A4%9C%E8%A8%BC%E7%94%A8%E3%81%ABRCW%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BeMMC%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81SW1%5B1%3A4%5D%E3%82%921001%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%80%8D%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2010.5pt%3B%22%3E%E7%A2%BA%E8%AA%8D%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81DDR%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%82%92%E9%80%B2%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22June_Lu_0-1788504721222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395908i184EA8655F628043%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22June_Lu_0-1788504721222.png%22%20alt%3D%22June_Lu_0-1788504721222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJune_Lu_0-1788504721222.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%AB%E3%83%BC%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ELX2160ARDB%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81u-boot%E3%82%BD%E3%83%BC%E3%82%B9%E5%86%85%E3%81%AEDDR%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82DIMM%E3%81%AESPD%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E2%80%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160ARDB%3A%20DDR%20validation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3EDIMM%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E6%A8%99%E6%BA%96%E3%81%AELX2160ARDB%E3%81%A7%E3%81%AF%E3%80%81DDR%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BDIMM%E3%81%8B%E3%82%89SPD%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFU-Boot%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81TF-A%20BL2%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%EF%BC%88ddr_init.c%EF%BC%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82LX2160ARDB%3C%2FSPAN%3E%3CSPAN%3E%E3%81%A7%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0DIMM%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81ATF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%E3%82%82%E3%81%97%E6%96%B0%E3%81%97%E3%81%84%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E9%81%A9%E5%88%87%E3%81%AB%E8%BF%BD%E8%B7%A1%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E6%96%B0%E3%81%97%E3%81%84%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E3%81%AE%E9%96%93%E6%B4%BB%E5%8B%95%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
