LS2044A: Codewarrior target connection
3,037件の閲覧回数
ramasubramanian
We are testing our custom hardware based on LS2044A.  We are facing issues with CW target connection.
We are using target initialization files from LS2044A_QDS.
The target initialization script fails when Reset() procedure is invoked.
We are unable to connect to the target.
ERROR: Target reset failed.
Please let us know how to resolve this issue
Rams
タグ(1)
4 返答(返信)
2,705件の閲覧回数
yipingwang
Hello Rams S,
  1. Please use hard-coded RCW on the target board, in CodeWarrior initialization file, please set "USE_SAFE_RCW" as "True".
In the following section, please configure a suitable RCW for your target board.
    if USE_SAFE_RCW:
        # Set rcw_src to hard-coded RCW option
        gdb.execute("monitor rcw source set 0x9F")
You also also could configure the target board to use hard-coded RCW through hardware switch setting.
  1. Please refer to "Figure 2-23. Reset architecture" and "Figure 2-24. JTAG/COP connections" in LS2088 Reference Manual downloaded from https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/qoriq-lay... to check your hardware design.
  2. If your problem remains, please refer to the following procedure to capture the protocol log to me to do more investigation.
Before connecting to the target board, please refer to the following to enable CCS protocol logging , then connect to the target board and capture the "Protocol logging Console".
You can do this by going to Window > Preferences > Target Connection Configuration > Logging Configuration > Logging level : Debug, Enable logging to Eclipse console.
Yiping
2,705件の閲覧回数
ramasubramanian
Hello Yiping Wang,
I tested on another prototype hardware and I am able to establish connection with USE_SAFE_RCW true.
But I could not access the NOR flash.
fl_current nor
fl_erase 0x200000 64
Erasing...
Flash programming operation failed.
Additional error details:
[FP: id verify fail]
Could you please help us with this error?
2,705件の閲覧回数
ramasubramanian
Do you have any feedback on the CCS logs?
2,705件の閲覧回数
ramasubramanian
Thanks for your support.  I tried using USE_SAFE_RCW.  I am getting remove failure reply E01.
Please find below the CCS protocol logging.
Rams
ccs_open
ipaddr = 127.0.0.1
port = 41475
timeout = 10
serverh = 0
ccs_open; ccs_error = 0
ccs_get_cc_config
serverh = 0
cc = 0
config_string =
ccs_get_cc_config; ccs_error = 23
Error message: CC not present
ccs_config_cc
serverh = 0
config_string = cwtap:00:04:9f:03:b1:92
ccs_config_cc; ccs_error = 0
ccs_set_connection_timeout
serverh = 0
timeout = 10
ccs_set_connection_timeout; ccs_error = 0
ccs_config_server
serverh = 0
cc = 0
server_config = 0
value = 16000
ccs_config_server; ccs_error = 0
ccs_get_config_chain
serverh = 0
ccs_get_config_chain; ccs_error = 0
ccs_config_chain
serverh = 0
cc = 0
ccs_config_chain; ccs_error = 39
Error message: Cortex-A72: Core not responding
ccs_get_subcore_error
serverh = 0
cc = 0
error = 5
chain_pos = 18
ccs_get_subcore_error; ccs_error = 0
serverh = 0
cc = 0
error = 5
chain_pos = 18
ccs_config_chain
serverh = 0
cc = 0
ccs_config_chain; ccs_error = 0
ccs_reset_to_user
serverh = 0
cc = 0
ccs_reset_to_user; ccs_error = 0
ccs_config_chain
serverh = 0
cc = 0
serverh = 0
serverh = 0
ccs_stop_core
coreh = [serverh:0;cc_index:0;chain_pos:18]
ccs_stop_core; ccs_error = 0
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_register; ccs_error = 0
ccs_run_core
ccs_run_core; ccs_error = 0
ccs_stop_core
coreh = [serverh:0;cc_index:0;chain_pos:26]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_run_core
ccs_stop_core
coreh = [serverh:0;cc_index:0;chain_pos:22]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_run_core
ccs_config_template
coreh = [serverh:0;cc_index:0;chain_pos:0]
config_reg = 4096
config_data = 1
ccs_config_template; ccs_error = 0
ccs_write_register
index = 0
count = 1
size = 4
ccs_write_register; ccs_error = 0
ccs_write_register
index = 4110
count = 1
size = 4
ccs_reset_to_debug
serverh = 0
cc = 0
ccs_reset_to_debug; ccs_error = 39
Error message: LS2080A: Core not responding
serverh = 0
cc = 0
error = 5
chain_pos = 0
ccs_config_template
config_reg = 4096
config_data = 0
ccs_delete_cc
serverh = 0
count = 0
ccs_delete_cc; ccs_error = 0
ccs_close
serverh = 0
ccs_close; ccs_error = 0
ccs_open
ipaddr = 127.0.0.1
port = 41475
timeout = 10
serverh = 0
ccs_get_cc_config
serverh = 0
cc = 0
config_string =
ccs_config_cc
serverh = 0
serverh = 0
timeout = 10
ccs_config_server
serverh = 0
cc = 0
server_config = 0
value = 16000
serverh = 0
ccs_config_chain
serverh = 0
cc = 0
serverh = 0
serverh = 0
ccs_stop_core
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000007;address_lo:0x0007002c]
ccs_write_memory; ccs_error = 0
ccs_run_core
ccs_stop_core
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01e60060]
ccs_run_core
ccs_stop_multi_core
chain_pos: (size = 4) { 18 22 26 30 }
ccs_stop_multi_core; ccs_error = 0
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240010]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240030]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240034]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022400c4]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240154]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240250]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240254]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240258]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0224025c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:1;address_hi:0x00000005;address_lo:0x20000000]
ccs_read_memory; ccs_error = 0
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0224000c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022400a0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240130]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022401c0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022401c4]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022401c8]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022401cc]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240024]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240028]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x022400b8]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240148]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240220]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240224]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x02240228]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0224022c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01100008]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01100128]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0110012c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01100130]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01100134]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01110008]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01110128]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0111012c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01110130]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01110134]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:1;address_hi:0x00000005;address_lo:0x20000030]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01e00100]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000007;address_lo:0x0012c800]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080130]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080000]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080080]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010800c0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080008]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080084]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010800c4]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080010]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080088]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010800c8]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080018]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108008c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010800cc]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080100]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080104]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080108]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108010c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080160]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080164]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080168]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108016c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080250]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080118]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108011c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080200]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080204]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080208]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108020c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080214]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080220]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080224]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080228]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108022c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080230]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080234]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080238]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108023c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080120]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080124]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080174]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080190]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080194]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080254]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080170]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080400]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080404]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080408]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108040c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080260]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080128]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108017c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080180]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080184]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010801a0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010801a4]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010801a8]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010801ac]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080b28]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080114]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080148]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0108014c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080b2c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080e44]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080e48]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080f70]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080110]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080f04]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01080e40]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000007;address_lo:0x0012d800]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090130]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090000]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090080]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010900c0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090008]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090084]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010900c4]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090010]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090088]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010900c8]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090018]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109008c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010900cc]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090100]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090104]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090108]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109010c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090160]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090164]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090168]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109016c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090250]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090118]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109011c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090200]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090204]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090208]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109020c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090214]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090220]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090224]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090228]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109022c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090230]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090234]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090238]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109023c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090120]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090124]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090174]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090190]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090194]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090254]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090170]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090400]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090404]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090408]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109040c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090260]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090128]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109017c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090180]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090184]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010901a0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010901a4]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010901a8]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x010901ac]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090b28]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090114]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090148]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x0109014c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090b2c]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090e44]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090e48]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090f70]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090110]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090f04]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x01090e40]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04000180]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x040001a0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x040001b0]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04000210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04200210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04210210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04220210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04230210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04240210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04250210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04260210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_write_memory
addr = [space:0x13ff;size:4;address_hi:0x00000000;address_lo:0x04270210]
ccs_read_register
index = 121384
count = 1
size = 4
ccs_read_register
index = 123008
count = 1
size = 4
ccs_stop_multi_core
ccs_read_register
index = 4130
count = 1
size = 4
ccs_read_register
index = 4130
count = 1
size = 4
ccs_read_register
index = 4130
count = 1
size = 4
ccs_read_register
coreh = [serverh:0;cc_index:0;chain_pos:30]
index = 4130
count = 1
size = 4
ccs_read_register
index = 4130
count = 1
size = 4
ccs_add_register_group
serverh = 0
cc = 0
chain_pos: (size = 58)
0x00000012 0x00000012 0x00000012 0x00000012
indices: (size = 58)
0x00005000 0x00005001 0x00005002 0x00005003
0x00005004 0x00005005 0x00005006 0x00005007
0x00005008 0x00005009 0x0000500A 0x0000500B
0x0000500C 0x0000500D 0x0000500E 0x0000500F
0x00005010 0x00005011 0x00005012 0x00005013
0x00005014 0x00005015 0x00005016 0x00005017
0x00005018 0x00005019 0x0000501A 0x0000501B
0x0000501C 0x0000501D 0x0000501E 0x00006000
0x0001DA29 0x0001DA28 0x00001022 0x0000100C
0x0000100D 0x00018004 0x00018005 0x00018006
0x00018007 0x0001800C 0x0001800D 0x0001800E
0x0001800F 0x00018014 0x00018015 0x00018016
0x00018017 0x0001801C 0x0001801D 0x0001801E
0x0001801F 0x00018024 0x00018025 0x0001802C
0x0001802D 0x0001C028
counts: (size = 58)
0x00000001 0x00000001 0x00000001 0x00000001
sizes: (size = 58)
0x00000008 0x00000008 0x00000008 0x00000008
0x00000008 0x00000004 0x00000004 0x00000004
0x00000004 0x00000008 0x00000004 0x00000008
handle = 0
ccs_add_register_group; ccs_error = 0
ccs_read_register_group
serverh = 0
cc = 0
handle = 0
ccs_read_register_group; ccs_error = 5
Error message: Core not responding
serverh = 0
cc = 0
handle = 0
ccs_read_register_group; ccs_error = 0
ccs_read_memory
addr = [space:0;size:4;address_hi:0x00000000;address_lo:0xfbd41bd4]
ccs_read_memory
addr = [space:0;size:4;address_hi:0x00000000;address_lo:0xfbd41bd0]
ccs_read_memory
ccs_run_multi_core
ccs_run_multi_core; ccs_error = 0
ccs_free_register_group
serverh = 0
cc = 0
handle = 0
ccs_free_register_group; ccs_error = 0
ccs_delete_cc
serverh = 0
count = 0
ccs_close
serverh = 0
