LS1023A CW bl2.elf load - RCW Error Encountered
1,501件の閲覧回数
ts1234
Why do I see the following message when trying to load bl2.elf from Code Warrior?
I have even tried Hard-Coded RCW option.
"RCW error encountered. In order to diagnose the error temporarily change the board configuration switches to ignore the assertion of the RESET_REQ_B signal. Please refer to board reference manual in order to locate the appropriate switch that controls this behavior."
0 返答(返信)
