Issue with CW IDE Version 5.7.1844 and C++
3,195 次查看
Anamika
I have got the CW IDE Version 5.7.1844 CW compiler and Coldfire 5275 CVM processor.  I am using Professional Edition of CW development Studio. I wanted to compile my C++ application and it couldn't recognise C++ keyword. Started giving all sorts of errors. But after few days, without any change it started working fine.
Today, I again wanted to compile my application and again it is not recognisng C++ keyword. Is it a known issue with this CW? Any workaround for this??
Thanks in advance for your time.
标记 (1)
1,685 次查看
CrasyCat
Specialist III
Hello
This is usually happening when you are returning back to Special Edition license.
C++ support is not included in special edition.
Did you use a temporary license? Perhaps the temporary license has expired.
If this does not help,  I would suggest you to submit a service request at http://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=054670.
Make sure to attach the license file you are currently using and specify where you installed the license file.
CrasyCat
