INTC_InstallINTCInterruptHandler
SeanW
How do you use the function in IntcInterrupts.c  -->
 INTC_InstallINTCInterruptHandler(INTCInterruptFn handlerFn, unsigned short vectorNum, unsigned char psrPriority);
I am trying to build a table of vector interrupts for the INTC module and can't get them to work. Any insight into how to use the intcinterrupts.c file would be great!
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
