Flash programming lite5200 version 2.0
1,887件の閲覧回数
gyzko
It seems that I screw up the u-boot on the flash memory of my lite5200 version 2.0 evaluation board when playing with ltib. So now, the board is doing nothing on reset...
I have a "WireTap PowerPC 6xx, 7xx, 7xxx, 8xxx" that connect to parallel port. It is possible to reprogram uboot image with this tools? Which version of CW I need to do that? (Linux of Windows host don't make difference too) There exists a "CW 101 of flash programming for MPC5200 eval board" ?
Thanks!
タグ(1)
1,046件の閲覧回数
CrasyCat
Specialist III
Hello
As far as I know you need CodeWarrior Development Studio, mobileGT(tm) Edition.
I am not aware of a 101 Flash programming guide for 5200, but you should be able to find some information on flash programming in the targeting manual.
CrasyCat
