Flash program device manufacturer id
PaulWalker
For the CodeWarrior Flash Programmer, does the programmer check the manufacturer id in the device config?
I want to use the S29GL-P flash algorithm to program my Micron MT28EW256 device. There isn't an existing device config for this device. If I use the S29GL256P device config I noted the manufacture id is not correct for my Micron device (0x89). Does this matter? Thanks.
<device-file>
<device>
<version>0.1</version>
<content>
<name>S29GL256P</name>
<device_type>nor</device_type>
<manufacturerid>0x01</manufacturerid>
<chiperase>true</chiperase>
<sectors>
<sectorcount>256</sectorcount>
<sectorsize>0x20000</sectorsize>
</sectors>
<ontargetverify>true</ontargetverify>
<comment>
PaulWalker
Ok. By your reply I assume the 'manufacturer id' does matter. Thus I need to create a new device config.
yipingwang
Please refer to section "4. Creating Flash Device XML Configuration File" in C:\Freescale\CW_PA_v10.5.1\PA\PA_Tools\FlashToolKit\Documentation\AppNote-FlashProgrammer-PowerArchitecture.pdf to create your own configuration file.
PaulWalker
%3CLINGO-SUB%20id%3D%22lingo-sub-2259800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlash%20program%20device%20manufacturer%20id%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EFor%20the%20CodeWarrior%20Flash%20Programmer%2C%20does%20the%20programmer%20check%20the%20manufacturer%20id%20in%20the%20device%20config%3F%3C%2FP%3E%3CP%3EI%20want%20to%20use%20the%20S29GL-P%20flash%20algorithm%20to%20program%20my%20Micron%20MT28EW256%20device.%20There%20isn't%20an%20existing%20device%20config%20for%20this%20device.%20If%20I%20use%20the%26nbsp%3BS29GL256P%20device%20config%20I%20noted%20the%20manufacture%20id%20is%20not%20correct%20for%20my%20Micron%20device%20(0x89).%20Does%20this%20matter%3F%20Thanks.%3C%2FP%3E%3CP%3E%3CDEVICE-FILE%3E%3CBR%20%2F%3E%3CDEVICE%3E%3CBR%20%2F%3E%3CVERSION%3E0.1%3C%2FVERSION%3E%3CBR%20%2F%3E%3CCONTENT%3E%3CBR%20%2F%3E%3CNAME%3ES29GL256P%3C%2FNAME%3E%3CBR%20%2F%3E%3CDEVICE_TYPE%3Enor%3C%2FDEVICE_TYPE%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CMANUFACTURERID%3E0x01%3C%2FMANUFACTURERID%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CCHIPERASE%3Etrue%3C%2FCHIPERASE%3E%3CBR%20%2F%3E%3CSECTORS%3E%3CBR%20%2F%3E%3CSECTORCOUNT%3E256%3C%2FSECTORCOUNT%3E%3CBR%20%2F%3E%3CSECTORSIZE%3E0x20000%3C%2FSECTORSIZE%3E%3CBR%20%2F%3E%3C%2FSECTORS%3E%3CBR%20%2F%3E%3CONTARGETVERIFY%3Etrue%3C%2FONTARGETVERIFY%3E%3CBR%20%2F%3E%26lt%3B%2FP%26gt%3B%26lt%3Bbr%20%2F%26gt%3B%26lt%3B%2Flingo-body%26gt%3B%26lt%3Blingo-sub%20id%3D%22lingo-sub-2259827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%26gt%3BRe%3A%20Flash%20program%20device%20manufacturer%20id%26lt%3B%2Flingo-sub%26gt%3B%26lt%3Blingo-body%20id%3D%22lingo-body-2259827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%26gt%3BOk.%20By%20your%20reply%20I%20assume%20the%20'manufacturer%20id'%20does%20matter.%20Thus%20I%20need%20to%20create%20a%20new%20device%20config.%26lt%3B%2Flingo-body%26gt%3B%26lt%3Blingo-sub%20id%3D%22lingo-sub-2259818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%26gt%3BRe%3A%20Flash%20program%20device%20manufacturer%20id%26lt%3B%2Flingo-sub%26gt%3B%26lt%3Blingo-body%20id%3D%22lingo-body-2259818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%26gt%3B%26lt%3BP%26gt%3BPlease%20refer%20to%20section%20%224.%20Creating%20Flash%20Device%20XML%20Configuration%20File%22%20in%26nbsp%3BC%3A%5CFreescale%5CCW_PA_v10.5.1%5CPA%5CPA_Tools%5CFlashToolKit%5CDocumentation%5CAppNote-FlashProgrammer-PowerArchitecture.pdf%20to%20create%20your%20own%20configuration%20file.%26lt%3B%2FP%26gt%3B%26lt%3B%2Flingo-body%26gt%3B%26lt%3B%2Flingo-body%26gt%3B%3C%2FCONTENT%3E%3C%2FDEVICE%3E%3C%2FDEVICE-FILE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
